PayGoneCray
Jun 12, 2023Aspirant
Port forwarding disconnects the whole internet CBR40
Hey there so I've been wanting to play with my friends and I'm the only one who knows how to port forward and everything so I do that. After a while my dad starts telling me the internet is messi...
PayGoneCray
Actually I just updated the Satellite and it's now V2.7.3.22 but the router still wont update as it's apparently the same firmware
Jun 12, 2023Guru - Experienced User
Ya that maybe a problem. Normally the RBS needs to use that same version of FW or near same version as what's loaded on the CBR. Any far out of range FW version could cause problems.
CBR is on 2.5x and the RBS is on 2.7x. Not sure how this would all work being kind of out of FW version range.
Might turn OFF the RBS and just test your configurations at the CBR first...
- PayGoneCrayJun 12, 2023Aspirant
Yes but if you have noticed those are the latest versions I installed so I don't know what's up.
- FURRYe38Jun 12, 2023Guru - Experienced User
Yes I know. Why we need to test with the CBR only for now.
I've pass this to NG for review as well.
- PayGoneCrayJun 13, 2023Aspirant
How would I even go on about testing that router alone?
