Magixians
Apr 27, 2020Tutor
Port forwarding does not take effect
Hi When I setup port forwarding on my Orbi unit, it does not take effect. I have forwarded the following ports to our PS4 console 80, 443, 1935, 3478-3480, 3074, 3659, 6000, 10000-10150, 421...
Apr 27, 2020Guru - Experienced User
- MagixiansApr 27, 2020TutorFirmware is V2.3.5.30
There is no modem. Router connected directly to WAN.- FURRYe38Apr 27, 2020Guru - Experienced User
What browser are you using?
Be sure to clear all browser caches before entering into the RBRs web page.
Has a factory reset and setup from scratch been performed since last update?
- MagixiansApr 27, 2020TutorYes
Three different browsers tested. But that shouldn't make any difference since the router reports the setting correct in the web browser even in a new browser that I tested. It just doesn't work when tested from either end.
- CrimpOnApr 27, 2020Guru - Experienced User
Magixians wrote:
There is no modem. Router connected directly to WAN.The Orbi router has to be connected to something. The Orbi has no connector for coax cable or for a fiber. The WAN (yellow) port must connect to some ISP device. Knowing the specific brand and model helps eliminate some possibilities.
