Magixians
Apr 27, 2020Tutor
Port forwarding does not take effect
Hi When I setup port forwarding on my Orbi unit, it does not take effect. I have forwarded the following ports to our PS4 console 80, 443, 1935, 3478-3480, 3074, 3659, 6000, 10000-10150, 421...
Apr 27, 2020Guru - Experienced User
Magixians
Apr 27, 2020Tutor
Firmware is V2.3.5.30
There is no modem. Router connected directly to WAN.
- FURRYe38Apr 27, 2020Guru - Experienced User
What browser are you using?
Be sure to clear all browser caches before entering into the RBRs web page.
Has a factory reset and setup from scratch been performed since last update?
- MagixiansApr 27, 2020TutorYes
Three different browsers tested. But that shouldn't make any difference since the router reports the setting correct in the web browser even in a new browser that I tested. It just doesn't work when tested from either end.- FURRYe38Apr 27, 2020Guru - Experienced User
So when you applying the configuration, is it the new configuration being seen on the web page or is the Port Forwarding opertation just not working?
Did you disable uPnP before entering the PF configuration?
If you have uPnP enabled, then any PF configursations should not be needed for PS game consoles. uPnP does all the work. If your in a single NAT condition. https://kb.netgear.com/30186/What-is-Double-NAT
- CrimpOnApr 27, 2020Guru - Experienced User
Magixians wrote:
There is no modem. Router connected directly to WAN.The Orbi router has to be connected to something. The Orbi has no connector for coax cable or for a fiber. The WAN (yellow) port must connect to some ISP device. Knowing the specific brand and model helps eliminate some possibilities.
