Trojan81
Sep 27, 2017Aspirant
Port Forwarding for Cameras behind ATT Router in IP Passthru
Hi Everyone, So I have ATT Fiber service using the Pace 5268AC modem in passthru mode (this modem is not capable of bridge mode) plugged into my orbi system. The Orbi is in DMZ from the ATT rout...
Mikey94025
Sep 27, 2017Hero
What port forwardings do you have setup? You should be able to port forward 80 and 6036 on the Orbi to the camera's Orbi-assigned IP as normal, also port forward 80 and 6036 on the ATT router to the Orbi's ATT-assigned IP address. Then from the outside port 80 and 6036 should go to your camera.
Trojan81
Because the Orbi is in DMZ, I cant forward anything else I dont think. Or I am not sure what to forward. The devices attached are Uverse TVs, nothing else is on that network.
