Trojan81
Sep 27, 2017Aspirant
Port Forwarding for Cameras behind ATT Router in IP Passthru
Hi Everyone, So I have ATT Fiber service using the Pace 5268AC modem in passthru mode (this modem is not capable of bridge mode) plugged into my orbi system. The Orbi is in DMZ from the ATT rout...
st_shaw
Sep 27, 2017Master
You could remove Orbi from the DMZ and switch Orbi to AP mode. Then manage forwarding from the ATT router.
waynealight
Sep 27, 2017Apprentice
so i have done this before on both routers. so just to cover the bases, you have the att router in passthough for the orbi and on the orbi the ip address is a WAN address and not a LAN address assigned by the att router? this is a major part of it working.
then on the orbi you have to set dmz to the camera system, then set a ftp port forwarding rule through the entire range of the ports you are needing to forward.
do you have ddns setup on the camera system and verified its working?
also you need upnp enabled on the orbi and camera system.
on the upnp tab in orbi you should the camera system show up and the ports that it is using.
the att router doesnt support upnp so it has to go through the orbi.
