Reith
Oct 29, 2019Apprentice
Port Forwarding for Tablo Quad
I am trying to set up port foward on my orbi router to lock in the Tablo i have. The UNPC is not working and I keep having to uncheck and check remote access. If I send screenshots can someon...
Oct 29, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Any built in router here by chance?
If uPnP is enabled on the RBR, then you may not need any PF configurations.
Reith wrote:I am trying to set up port foward on my orbi router to lock in the Tablo i have. The UNPC is not working and I keep having to uncheck and check remote access.
If I send screenshots can someone guide on how to set this up correctly
Thank you in advance
- ReithOct 29, 2019Apprentice
My current Orbi firmware is 2.5.0.38
My Modem is Arris TM1602
Please see attached screenshot of the error I keep getting
- CrimpOnOct 29, 2019Guru - Experienced User
I keep forgetting to ask how you administer the Orbi: using the Orbi web interface or using the Orbi "app".
Port forwarding can be set up only using the web interface.
It is on the Advanced Tab->Advanced Setup->Port Forwarding/Port Triggering. This is described in Chapter 8 of the Orbi User Manual:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- Nyirishman1877Oct 29, 2019AspirantI know where to go to get to the port forward feature.
What I am asking is based on the attachment I included. How do I set it up?
