Reith
Oct 29, 2019Apprentice
Port Forwarding for Tablo Quad
I am trying to set up port foward on my orbi router to lock in the Tablo i have. The UNPC is not working and I keep having to uncheck and check remote access. If I send screenshots can someon...
Oct 29, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Any built in router here by chance?
If uPnP is enabled on the RBR, then you may not need any PF configurations.
Reith wrote:I am trying to set up port foward on my orbi router to lock in the Tablo i have. The UNPC is not working and I keep having to uncheck and check remote access.
If I send screenshots can someone guide on how to set this up correctly
Thank you in advance
Reith
My current Orbi firmware is 2.5.0.38
My Modem is Arris TM1602
Please see attached screenshot of the error I keep getting
