Reith
Oct 29, 2019Apprentice
Port Forwarding for Tablo Quad
I am trying to set up port foward on my orbi router to lock in the Tablo i have. The UNPC is not working and I keep having to uncheck and check remote access. If I send screenshots can someon...
Reith
My current Orbi firmware is 2.5.0.38
My Modem is Arris TM1602
Please see attached screenshot of the error I keep getting
CrimpOn
Oct 29, 2019Guru - Experienced User
I keep forgetting to ask how you administer the Orbi: using the Orbi web interface or using the Orbi "app".
Port forwarding can be set up only using the web interface.
It is on the Advanced Tab->Advanced Setup->Port Forwarding/Port Triggering. This is described in Chapter 8 of the Orbi User Manual:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- Nyirishman1877Oct 29, 2019AspirantI know where to go to get to the port forward feature.
What I am asking is based on the attachment I included. How do I set it up?- CrimpOnOct 29, 2019Guru - Experienced User
Nyirishman1877 wrote:
I know where to go to get to the port forward feature.Great, navigate to Advanced Tab->Advanced Setup->Port Forwarding. Then,
- Turn on Port Forwarding
- Click "Add a Custom Service"
- Give it a name, such a Quad1
- Enter the external port information "21308"
- Uncheck "Use the same internal"
- Enter the internal port "8887"
- Enter the IP address of the Quad "128"
- Click "Apply"
- Give it another name, such as Quad2
- Enter the external port information "21307"
- Uncheck "Use the same Internal"
- Enter the internal port "80"
- Click "Apply"
Port forwarding is now set up. Go back to the Quad, go to the same page, and click "Test.."
Good Luck
- ReithOct 29, 2019Apprentice
It seems to have worked. I had to turn off UPNP option to get the second quad 2 set up. Can I turn it back on now?
Also do I leave the Protocol TCP/UDP?
