Reith
Oct 29, 2019Apprentice
Port Forwarding for Tablo Quad
I am trying to set up port foward on my orbi router to lock in the Tablo i have. The UNPC is not working and I keep having to uncheck and check remote access. If I send screenshots can someon...
CrimpOn
Oct 30, 2019Guru - Experienced User
Nyirishman1877 wrote:
I know where to go to get to the port forward feature.
Great, navigate to Advanced Tab->Advanced Setup->Port Forwarding. Then,
- Turn on Port Forwarding
- Click "Add a Custom Service"
- Give it a name, such a Quad1
- Enter the external port information "21308"
- Uncheck "Use the same internal"
- Enter the internal port "8887"
- Enter the IP address of the Quad "128"
- Click "Apply"
- Give it another name, such as Quad2
- Enter the external port information "21307"
- Uncheck "Use the same Internal"
- Enter the internal port "80"
- Click "Apply"
Port forwarding is now set up. Go back to the Quad, go to the same page, and click "Test.."
Good Luck
Reith
Oct 30, 2019Apprentice
It seems to have worked. I had to turn off UPNP option to get the second quad 2 set up. Can I turn it back on now?
Also do I leave the Protocol TCP/UDP?
- CrimpOnOct 30, 2019Guru - Experienced User
The instructions said "TCP". Saying "TCP/UDP" is not necessary, but probably does not hurt. I would follow their dorections. (Sorry, I got in a hurry and typed before thinking.)
UPNP .... beats me.
