Darryl66
Jul 25, 2019Aspirant
Port Forwarding kills internet on Orbi
Hi I am having issues setting up port forwarding on my Orbi router, what happens when I set the port forwarding rule up the internet stops working delete the rule and the internet starts working...
Jul 25, 2019Guru - Experienced User
Both wired and wireless internet access goes down?
How do you have Port forwarding configured?
Did you disable uPnP before setting up any PF rules?
Darryl66 wrote:Hi
I am having issues setting up port forwarding on my Orbi router, what happens when I set the port forwarding rule up the internet stops working delete the rule and the internet starts working. The rule I am setting up is a port 8080 to an IP address on me network
The set up I have is VM Router in Modem mode Orbi 50 running with one satalite I have checked for double NAT and there is not one I only get the router IP when doing a tracecert
