SupahFox
Apr 20, 2019Tutor
Port Forwarding not working
Hello. Recently I wanted to open a dedicated server for csgo, which port is 27015. But it doesn't works, I tried to make a port test and this happened. Any solution? (That's weird because I have the ...
Mooose
Apr 21, 2019Luminary
Works for me.
Have you checked that 10.0.0.2 responds as expected on 27015 from the internal network?
- SupahFoxApr 21, 2019Tutor
Yep, I executed netstat -an and it doesn't appear 10.0.0.2:27015.
Also, I did a port test on whatsmyip and it shows me this
- MoooseApr 21, 2019Luminary
Is 10.0.0.2 the computer running the service or your router? If the latter, you need to forward it to the IP address of the computer where the required service is running instead.
Yup, 10.0.0.2 is the computer's internal IP adress
