SupahFox
Apr 20, 2019Tutor
Port Forwarding not working
Hello. Recently I wanted to open a dedicated server for csgo, which port is 27015. But it doesn't works, I tried to make a port test and this happened. Any solution? (That's weird because I have the ...
Mooose
Apr 21, 2019Luminary
SupahFox wrote:
Yep, I executed netstat -an and it doesn't appear 10.0.0.2:27015.
Is 10.0.0.2 the computer running the service or your router? If the latter, you need to forward it to the IP address of the computer where the required service is running instead.
SupahFox
Apr 21, 2019Tutor
Yup, 10.0.0.2 is the computer's internal IP adress
