SupahFox
Apr 20, 2019Tutor
Port Forwarding not working
Hello. Recently I wanted to open a dedicated server for csgo, which port is 27015. But it doesn't works, I tried to make a port test and this happened. Any solution? (That's weird because I have the ...
SupahFox
Apr 22, 2019Tutor
I can only access modem control panel while the NG router is in AP Mode. Its 10.0.0.1
Apr 22, 2019Guru - Experienced User
So the Orbi is in AP mode Then you shouldn't have a problem.
Seems like this is a NAT issue.
Can you try putting the ISP Modem back to router mode and connect your PC there and see if Port fowarding works there?
THen try connecting the Orbi in AP mode to the ISP modem in router mode and try your remote devices.
- SupahFoxApr 22, 2019TutorI can't put the ISP Modem back into router mode, only ISP can do that. And no, this modem don't have port forwarding
