CarlE123
Apr 26, 2020Aspirant
Port forwarding not working
Hei have been trying to port forward my router so me and my friend can play call of duty bo4 together, but it doesn't seem to work
Apr 28, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
CarlE123
May 01, 2020Aspirant
i set my modem to bridge mode but its still not working tho
- CrimpOnMay 01, 2020Guru - Experienced User
Probably worth a minute to double check that the Orbi router "internet address" matches the public IP address reported by any of the port scanning web sites, such as Gibson Security "Sheild's Up!": https://www.grc.com/x/ne.dll?bh0bkyd2
- CarlE123May 02, 2020Aspirant
And if it matches then what
