CarlE123
Apr 26, 2020Aspirant
Port forwarding not working
Hei have been trying to port forward my router so me and my friend can play call of duty bo4 together, but it doesn't seem to work
CarlE123
May 02, 2020Aspirant
its the right ip but its says connection timed out when I check for open ports
CrimpOn
May 02, 2020Guru - Experienced User
CarlE123 wrote:its the right ip but its says connection timed out when I check for open ports
Can you make a screen shot of this message? What is "timing out"?
- CarlE123May 04, 2020Aspirant
- CrimpOnMay 04, 2020Guru - Experienced User
Thanks for providing the screen shot. I had hoped it would give some indication of "what" was looking for the open port.
i.e. is this a computer or smartphone on the LAN?
a web site on the internet?
- CarlE123May 07, 2020Aspirant
its on my computer. And i have stopped the port forwarding attempt because I don't really need it but I have a new issue now when I try to play csgo I cant connect to servers with the port 27017
