max14
Jul 20, 2020Aspirant
Port forwarding now working
Hi everybody, I have the Orbi RBR50 running firmware V2.5.1.8 trying to forward a port. My routers LAN address is 192.168.1.1 and the WAN address is 192.168.0.100. The modem is set route mode a...
Jul 20, 2020Guru - Experienced User
Probably due to your modem having a router built in already. This would be a double NAT (two router) condition which isn't recommended and would cause port forwarding to not work right on the Orbi router. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
