max14
Jul 20, 2020Aspirant
Port forwarding now working
Hi everybody, I have the Orbi RBR50 running firmware V2.5.1.8 trying to forward a port. My routers LAN address is 192.168.1.1 and the WAN address is 192.168.0.100. The modem is set route mode a...
CrimpOn
Jul 20, 2020Guru - Experienced User
https://kb.netgear.com/30186/What-is-Double-NAT
max14 wrote:I have the Orbi RBR50 running firmware V2.5.1.8 trying to forward a port.
This is the problem. The Orbi is connected to a router. That router will block all incomming connection attempts.
Netgear describes this as a Double NAT: https://kb.netgear.com/30186/What-is-Double-NAT
Nothing done on the Orbi will fix this. There are basically two alternatives:
- Place the Orbi in Access Point (AP) mode and learn how to configure port forwarding on the ISP router, or
- Place the ISP router into "bridge" mode (sometimes called "passthrough" mode).
I would start with a call to the ISP tech support and tell them, "Please put my router into bridge mode (and disable WiFi while you are at it).
