VenomBoiiii
Aug 19, 2020Aspirant
Port forwarding ports closed
I have all my portforwarding options set up and have been doublechecking and troubleshooting that everything is correct for the past several hours and whenever I use a port checker it says they are c...
VenomBoiiii
What do I do if it is private? Should I simply change the WAN IP to the same as my router's?
Aug 19, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If there is a built in router at the modem, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
VenomBoiiii wrote:What do I do if it is private? Should I simply change the WAN IP to the same as my router's?
