VenomBoiiii
Aug 19, 2020Aspirant
Port forwarding ports closed
I have all my portforwarding options set up and have been doublechecking and troubleshooting that everything is correct for the past several hours and whenever I use a port checker it says they are c...
VenomBoiiii
What do I do if it is private? Should I simply change the WAN IP to the same as my router's?
CrimpOn
Aug 19, 2020Guru - Experienced User
VenomBoiiii wrote:What do I do if it is private? Should I simply change the WAN IP to the same as my router's?
First, does the Orbi WAN interface have (or not have) a "private" IP?
If it does, then FURRYe38 has explained the three alternatives. If it does not.........
