evdog199
Jul 22, 2018Tutor
Port forwarding problem RBR50
I am creating a server on the port 25565. Port forwarding seems to work and I even check if the port is open with a port checker it says its open. But when freinds try to join off the external ip add...
Jul 23, 2018Guru - Experienced User
If you have PF configured, be sure to disable uPnP on the router.
