cliyeh
Nov 03, 2022Aspirant
Port Forwarding RBR50 & Spectrum Modem
Trying to do port forwarding on port 563. I've entered everything correctly per instructions and Youtube videos. However when I go to sites like canyouseeme.org or portchecker.co and test, they all...
Mikey94025
Nov 03, 2022Hero
cliyeh wrote:Trying to do port forwarding on port 563. I've entered everything correctly per instructions and Youtube videos. However when I go to sites like canyouseeme.org or portchecker.co and test, they all come back saying it's closed. Is there something I'm doing wrong. I've disabled all windows firewall on the PC I've forwarded to. I've disabled AV FW as well. I've called Spectrum and was told that all controls are by the router.
What are you running on port 563 and can you reach it from another device on your home network? That will test whether the problem is with the Orbi vs. on the Windows PC.
Also verify all the steps in the community FAQ, particularly verify you don't have Double NAT: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Community-FAQ-My-Orbi-port-forwarding-doesn-t-work/td-p/1984296
