cliyeh
Nov 03, 2022Aspirant
Port Forwarding RBR50 & Spectrum Modem
Trying to do port forwarding on port 563. I've entered everything correctly per instructions and Youtube videos. However when I go to sites like canyouseeme.org or portchecker.co and test, they all...
CrimpOn
Nov 03, 2022Guru - Experienced User
Could you do me a favor and try Gibson Research Shields Up! https://www.grc.com/shieldsup ??
Does it report port 563 Closed or Stealth?
Explanation: For testing, I often forward a port to a Pi-hole server which hosts a web interface. (and shut down the forwarding as soon as my test is completed). In my experience, Orbi port forwarding works as it should. Just for fun, I forwarded port 80 (http) to a non-existent device (192.168.1.150 which is not actually a device). Shields Up! reports my public IP port 80 is Stealth because the connection attempt simply disappears. No response of any kind. If the connection attempt had been refused, then the report would be Closed.
cliyeh
Nov 04, 2022Aspirant
Not sure why, but I ended up reboot the router after the changes were made and it works now. I thought the port forwarding changes didn't require reboot. Thanks for everything.
