orbi1973
Aug 24, 2020Aspirant
Port forwarding with bridged modem
Hi, i am writing this here after being on hold with Netgear support for more than an hour. I hope someone can help. I purchased an Orbi RBR50 AC3000 router a few weeks back. The router is connec...
- Aug 25, 2020
thank you both for your response. I was able to get port fowarding working. I had another router that was connected to my Obri that was then connected to the CCTV box. I put that router on AP mode. It was in regular router mode before and I believe that was probably what was causing the ping to fail. Thanks again.
CrimpOn
Aug 24, 2020Guru - Experienced User
orbi1973 wrote:I purchased an Orbi RBR50 AC3000 router a few weeks back. The router is connected to my Bell DSL modem, which is set on bridgemode. On my Orbi, under advanced setup, port fowarding, i've gone and added port 9999 in both external and internal ports. The protocall is TCP (i've also tried TCP/UDP). Port is 192.168.3.250. (I had set my Orbi gateway to 192.168.3.1).
When i go to https://www.canyouseeme.org/ and check for my port 9999, it's telling me it's not open.
The first check is whether the Bell modem is actually in bridge mode. Open the Orbi web interface and record the IP address shown on the Advanced Tab home page in the upper right box under "Internet Port". Does this match the IP address that canyouseeme reports?
Or, is it a "private" IP address: https://en.wikipedia.org/wiki/Private_network
Next: I seem to remember that "250" may be a "special" IP address. Can you try anything lower?
Last, the device that the port is forwarded to must be "open" and listening on that port for canyouseeme to report success. The Windows firewall, for example, rejects ALL incomming connections unless the user specifically allows connections.
- orbi1973Aug 25, 2020Aspirant
- MstrbigAug 25, 2020Master
Glad you got it figured out.
- FURRYe38Aug 25, 2020Guru - Experienced User
Please mark your thread as solved so others will know.
Thankl you, :smileywink:
orbi1973 wrote:thank you both for your response. I was able to get port fowarding working. I had another router that was connected to my Obri that was then connected to the CCTV box. I put that router on AP mode. It was in regular router mode before and I believe that was probably what was causing the ping to fail. Thanks again.
