orbi1973
Aug 24, 2020Aspirant
Port forwarding with bridged modem
Hi, i am writing this here after being on hold with Netgear support for more than an hour. I hope someone can help. I purchased an Orbi RBR50 AC3000 router a few weeks back. The router is connec...
- Aug 25, 2020
thank you both for your response. I was able to get port fowarding working. I had another router that was connected to my Obri that was then connected to the CCTV box. I put that router on AP mode. It was in regular router mode before and I believe that was probably what was causing the ping to fail. Thanks again.
orbi1973
Aug 25, 2020Aspirant
Mstrbig
Aug 25, 2020Master
Glad you got it figured out.
