rexon1273
Jul 02, 2022Aspirant
port forwarding won't work on orbi RBR50
I am unable to open ports on my network. I'm trying to set up some game servers and nothing never works and when testing the ports on https://canyouseeme.org/, they always appear closed Can someone ...
Mikey94025
Jul 06, 2022Hero
rexon1273 wrote:umm there's seem to be a mismatch between what is shown to be my ip on https://www.canyouseeme.org and my actual ip on the router page.
We can't see the image immediately unless you attach it vs. insert in-line. Can you just type in the IP address shown by canyouseeme and what your Orbi says?
It sounds like you may have Double NAT and that would explain why port forwarding doesn't work (it needs to be forwarded past 2 hops). What exactly is the Orbi connected to upstream (make and model of device please)? It may be a router vs. a straight modem, in which case putting it in bridge mode would help.
CrimpOn
Jul 06, 2022Guru - Experienced User
That image was marked Rejected, which is why is does not appear.
(My guess is that a moderator felt that publishing a public IP address is risky behavior.)
