DerfW
Nov 29, 2023Aspirant
Port Forwarding
Hi, I noticed the other day that I can no longer access my cameras away from home. Checked the ports that were forwarded and they all are closed now. Ports have been open for 9+ years but all of a sud...
DerfW
Nov 30, 2023Aspirant
The Model is RBR50.
Firmware version: v2.7.4..24
I am not sure if the firmware has been updated between the last time port forwarding was checked. I periodically log into the router and check for updates.
I checked to see if port forwarding was working by attempting to connect to a camera and DVR and the camera connection failed and all camera connections fail in the dvr. After that, I used an online tool to see if the port s to the cameras and dvr were open and it says they are closed. I have static IP addresses on my cameras and dvr and have those reserved in the Orbi to those cameras and dvr. The Port forwarding definitions are the same as before.
CrimpOn
Nov 30, 2023Guru - Experienced User
This is the key. If the router is still forwarding incoming connections on specific ports to specific devices on the LAN, then the issue is most likely the public IP address. (I was totally unable to come up with an explanation for how the port forwarding definitions would just "disappear" from the router configuration. Glad that is not the issue.)
I think what schumaku and I are focused on is how you are attempting to connect to the DVR and individual cameras:
- Are you connecting to a specific public IP address? If so, does it match the public IP address of the Orbi router?
- Are you connecting to a URL? If so, does the URL point to the public IP address of the Orbi router?
The public IP address assigned to the router is shown on the Orbi web interface Advanced Tab Home Page:
This is the IP address that can be tested with those web based "are ports open?" tools, and it must be the IP address that is used to access the cameras and DVR.
