Atlixnor
Dec 22, 2021Guide
Port mirroring to LAN port - Is it working now?
Searched for a guide how to set this up. According to this post it is not working: https://community.netgear.com/t5/Orbi/quot-WAN-Port-mirror-to-LAN-port1-quot-Not-Working/td-p/1971083 Debugging...
- Dec 22, 2021
Good Luck. I was bitterly disappointed when I tried it, but that was over a year ago. I wanted to see every packet that appeared on the WAN port, both to the Orbi and from the Orbi, for as long as I had disk space to hold. The option to Enable LAN/WAN packet capture creates circular files in system memory (or in my case on a USB stick in my Version 1 Orbi's USB port) and they do not hold much. I wanted to let Wireshark run for over 24 hours so I could watch my Orbi renew the DHCP lease from Spectrum.
CrimpOn
Dec 22, 2021Guru - Experienced User
I was the person who was disappointed with "WAN Mirror to LAN Port 1", and I still cannot find that post explaining what it actually does.
At one time, Netgear had two separate firmware versions for the RBR50 that were based on some vague difference between US and the rest of the world, perhaps having to do with licensing Disney Circle. That is no longer the case. The RBR50 has only one universal firmware version. In part of (most of? all of?) the world Netgear is now forcing a firmware update to V2.7.3.22. If the user loads a previous version, then Netgear updates back to V2.7.3.22 again almost immediately. There are methods to prevent this.
