BigDingus
Dec 22, 2021Tutor
Port Scanning from the same IP
Hi all. From my firewall log I can see there have been numerous attemps to access my PC from the same IP address. Is there a way to block the IP address at my router so it never gets as far as my P...
BigDingus
Dec 22, 2021Tutor
My firmware is V2.7.3.22
I don't know what model the modem is. Just that it's from Virginmedia
I just had a look. There's loads to port 80
My log:
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 16:26:17
[remote login] from source 152.251.1.202, Wednesday, December 22, 2021 16:26:00
[remote login failure] from source 152.251.1.202, Wednesday, December 22, 2021 16:25:56
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 16:19:39
[DHCP IP: 152.251.1.11] to MAC address be:50:35:f3:24:21, Wednesday, December 22, 2021 16:19:33
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 16:02:21
[LAN access from remote] from 218.0.246.117:33093 to 152.251.1.202:80, Wednesday, December 22, 2021 16:02:11
[LAN access from remote] from 218.0.246.117:33094 to 152.251.1.202:80, Wednesday, December 22, 2021 16:02:10
[LAN access from remote] from 218.0.246.117:33091 to 152.251.1.202:80, Wednesday, December 22, 2021 16:02:09
[LAN access from remote] from 218.0.246.117:33090 to 152.251.1.202:80, Wednesday, December 22, 2021 16:02:08
[LAN access from remote] from 218.0.246.117:33092 to 152.251.1.202:80, Wednesday, December 22, 2021 16:02:07
[LAN access from remote] from 218.0.246.117:33025 to 152.251.1.202:80, Wednesday, December 22, 2021 16:02:05
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:53:41
[DoS Attack: SYN/ACK Scan] from source: 170.33.12.120, port 8585, Wednesday, December 22, 2021 15:53:27
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:51:15
[DoS Attack: SYN/ACK Scan] from source: 168.119.232.76, port 443, Wednesday, December 22, 2021 15:51:08
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:49:37
[DoS Attack: SYN/ACK Scan] from source: 95.217.31.46, port 443, Wednesday, December 22, 2021 15:49:34
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:41:48
[LAN access from remote] from 2.57.121.26:47266 to 152.251.1.202:80, Wednesday, December 22, 2021 15:41:32
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:38:09
[LAN access from remote] from 14.4.62.35:52964 to 152.251.1.202:80, Wednesday, December 22, 2021 15:37:48
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:37:18
[LAN access from remote] from 211.111.237.31:43026 to 152.251.1.202:80, Wednesday, December 22, 2021 15:37:07
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:36:29
[LAN access from remote] from 45.95.147.17:46229 to 152.251.1.202:80, Wednesday, December 22, 2021 15:36:08
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:25:43
[LAN access from remote] from 209.141.50.223:53816 to 152.251.1.202:80, Wednesday, December 22, 2021 15:25:18
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:25:17
[LAN access from remote] from 209.141.50.223:33164 to 152.251.1.202:80, Wednesday, December 22, 2021 15:25:17
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:21:05
[DoS Attack: SYN/ACK Scan] from source: 162.241.216.182, port 443, Wednesday, December 22, 2021 15:20:42
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:01:38
[DHCP IP: 152.251.1.12] to MAC address 48:a6:b8:84:74:84, Wednesday, December 22, 2021 15:01:13
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 15:00:23
[DoS Attack: SYN/ACK Scan] from source: 168.119.232.76, port 443, Wednesday, December 22, 2021 15:00:10
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 14:57:57
[LAN access from remote] from 37.0.10.73:55731 to 152.251.1.202:80, Wednesday, December 22, 2021 14:57:42
[LAN access from remote] from 37.0.10.73:55580 to 152.251.1.202:80, Wednesday, December 22, 2021 14:57:40
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 14:56:18
[LAN access from remote] from 45.61.188.2:39960 to 152.251.1.202:80, Wednesday, December 22, 2021 14:55:53
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 14:54:14
[LAN access from remote] from 128.14.209.170:51546 to 152.251.1.202:80, Wednesday, December 22, 2021 14:54:00
[LAN access from remote] from 128.14.209.170:50522 to 152.251.1.202:80, Wednesday, December 22, 2021 14:53:59
[LAN access from remote] from 128.14.209.172:20884 to 152.251.1.202:80, Wednesday, December 22, 2021 14:53:58
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 14:50:09
[remote login] from source 152.251.1.202, Wednesday, December 22, 2021 14:50:06
[UPnP set event: add_nat_rule] from source 152.251.1.19, Wednesday, December 22, 2021 14:36:03
[Log Cleared] Wednesday, December 22, 2021 14:35:43
Dec 22, 2021Guru - Experienced User
Please find brand and model# information of ISP modem.
So a who is look up on those IP addresses.
152.251.1.202 is not a normal LAN side IP address string. 10. or 172. or 192. is LAN side string numbers.
What devices do you all have connected?
