Guldhammeren
Sep 27, 2020Aspirant
Portforward not working
I have set up portforwarding, but when i check whit open port check online, its shown as closed ? All port are shown as closed, eks, 21 80, and my new one 40000. I have fiber internet, and use ...
Sep 27, 2020Guru - Experienced User
To accrately check the port status, you have to be activly using the ports prior to testing the status.
Be sure uPnP is disabled on the RBR as well if you have PF configurations enabled.
