Guldhammeren
Sep 27, 2020Aspirant
Portforward not working
I have set up portforwarding, but when i check whit open port check online, its shown as closed ? All port are shown as closed, eks, 21 80, and my new one 40000. I have fiber internet, and use ...
Sep 27, 2020Guru - Experienced User
To accrately check the port status, you have to be activly using the ports prior to testing the status.
Be sure uPnP is disabled on the RBR as well if you have PF configurations enabled.
Guldhammeren
Firmware V2.5.1.16
Connected to fiber/router thats in Bridge mode, and use ORBI as router.
Have tryed to check/ uncheck UPnP.
The only port thas open, are the one for remotecontrol of the router.
No else port are open ?
- FURRYe38Sep 27, 2020Guru - Experienced User
It's up to the client app or a device to be actively using the port to check port status. If the port is not being used actively, then the port will be closed and report as such. Just be cause you set the port configuration on the router doesn't mean the port will be opened. Only when a app or device accesses the port will the port status change.
- Mikey94025Sep 27, 2020Hero
How are you checking that the port is open? What purpose is the open port used for? What device is opening the port, e.g., is it a Windows host and therefore you need to disable the firewall and make that connection "private"?
I like to use https://canyouseeme.org/ to check that the port is open. The Your IP displayed should also match the Internet Port IP Address displayed in the Advanced tab of http://orbilogin.com/
