Hockey1166
Sep 14, 2020Aspirant
Ports on RBK50 vs. RBK 43s
Does the RBK50 have fewer ports than the RBK 43s or the same? Also, is the coverage better or worse with a 3 pack RBK43s vs. a 2 pack RBK50?
Mstrbig
Sep 14, 2020Master
Hockey1166 wrote:Does the RBK50 have fewer ports than the RBK 43s or the same? Also, is the coverage better or worse with a 3 pack RBK43s vs. a 2 pack RBK50?
RBK50 has same plugin ports per unit. The coverage would depend on your distancing of the satellites. The RBR50 AC3000 router and RBS50 AC3000 satellite have a much faster backhaul channel with more antennas as well. I think overall the RBK50 would outperform the RBK43.
- Hockey1166Sep 14, 2020Aspirant
Thanks for the reply. I'm glad you clarified the ports because a Best Buy store rep. indicated the RBK 50 had only three ports versus seven for RBK43s. It seemed strage considering RBK50 is a more advanced unit, at least based on your response bellow.
- FURRYe38Sep 14, 2020Guru - Experienced User
