Mkstretch
Jun 13, 2020Aspirant
Position advice
I have the rbr20 with 2 satellites. I'm only using 1 satellite at the moment. I believe the satellite is about 40ft or so away from the router on the second floor. The router is on my main floor(1s...
Jun 13, 2020Guru - Experienced User
Either would work. Just as long as you dont put the RBR in a basement.
