edeka3
May 13, 2019Aspirant
Possible Bug Report: PPPoE disables itself on RBR50 V2.3.1.60
I have a problem with the latest V2.3.1.60 on my RBR50! The router's PPPoE connection works fine for hours and then turns itself off, so we end up in Double NAT all over again after some time. ...
May 13, 2019Guru - Experienced User
Can you try the ISP modem in router mode then set up the Orbi for standard DHCP and no PPPoE settings? Disable ALL wifi radios on the ISP modem, configure the ISP modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the ISP modem. DMZ on the modem will help with double NAT issues. You have to use the DMZ on the modem to avoid this.
edeka3
DMZ on my Modem does not exist. AVM says it's called exposed host (forwarding all ports). Wouldn't that make it unsafe? I just want to be sure before I do it :)
- FURRYe38May 13, 2019Guru - Experienced User
Oh ok, try that.
Using the DMZ or Exposed Host is no different than using a stand alone modem that doesn't have a built in Firewall in the first place, and the Orbi in router mode. The main Firewall just moves from modem to Orbi since Orbi has a built in firewall was well. Were just by passing the Firewall on the modem. The Firewall on the Orbi will keep you safe.
- edeka3May 13, 2019AspirantHello! I noticed in my Fritzbox log that at the time the RBR50 disabled the PPPoE my ISP remotely applied settings to my modem and directly after that the internet connection dropped.
Could it be that this interfered with it?
I wrote my ISP and hope I'll have an answer by tomorrow. For now I will leave the settings as they are since I assume this might have caused the problem, what do you think?- FURRYe38May 13, 2019Guru - Experienced User
Yes, if the ISP is remotely doing something to the modem and or PPPoE services on the line, this would effect Orbi and the connections. Changes on the line would need to be applied by rebooting the Orbi.
