SetMeUP
Jan 22, 2019Aspirant
Possible set up RBK23 with Ethernet backhaul
Hello Everyone,
So I'm looking to buy this Package from Amazon. The RBK23.
https://www.amazon.com/NETGEAR-Orbi-Ultra-Performance-Whole-System/dp/B07CQDHPFT/ref=sr_1_1?ie=UTF8&qid=1548227...
SetMeUP
Jan 23, 2019Aspirant
The ISP modem is also a router. Right now I currently have a router connected to my ISP modem, with the modem's wifi turned off. So it basically is just providing ethernet to the router we currently use and a handful of other appliances. I'm not sure what you mean by mide.
So is it possible that since my ISP modem is a modem/router, that I can go with the set up that I described? Using the Orbi router and one satellite as access points and have the Orbi satellite connected wirelessly to one of the Orbi access points?
I only have one ethernet going from the modem to the where the Orbi router would be. So there's no way for me to get the modem to connect to the Orbi router and then run another ethernet to the satellite. This means I can't run the set up you show in your picture unless I run another wire. Which I would rather not do, but I can do. Also, I don't need a switch, right? I can just get an Ethernet Extender like one in the link shown below correct?
Which configuration would you recommend?
Thank you again for taking the time to answer my question. I appreciate it very much.
randomousity
Jan 23, 2019Luminary
Can you do something like this (either choose option 1 in both places, or option 2 in both places)? Bridge mode and AP mode are basically the same thing, and, generally, you only want one device acting as a router on your network. That should be true of your current setup, as well as if/when you switch to an Orbi setup instead. Also, the only ethernet link you need is between your modem and the Orbi router. Depending on distance and obstacles between the Orbi router and satellites, you can just use the built-in wireless backhaul.
- SetMeUPJan 23, 2019Aspirant
Yea I'll likely be going with this setup. Seems that it will be the easiest to set up the hardest part will be to run another cable.
Thank you for your advice.
