SetMeUP
Jan 22, 2019Aspirant
Possible set up RBK23 with Ethernet backhaul
Hello Everyone,
So I'm looking to buy this Package from Amazon. The RBK23.
https://www.amazon.com/NETGEAR-Orbi-Ultra-Performance-Whole-System/dp/B07CQDHPFT/ref=sr_1_1?ie=UTF8&qid=1548227...
brettich
Jan 23, 2019Guide
I have the RBK23 set configured for wired ethernet backhaul.
Looks like this:
ISP Modem <> Dedicated Router (R7000 running AdvancedTomato) <> 1G unmanaged switch <> RBK23 (in AP mode)
- each of the RBS20 satellites are also connected to the 1G switch. I have 1 AP on each floor of the house.
- currently running FW V2.2.1.210
I'll be honest, I'm a technical person working in IT and the setup was NOT easy. Lots of reboots, firmware updates, factory resets... at one point I bricked one of the AP's and needed to recover it via SFTP -manually installing the firmware...
Need to methodically (slowly) get one node running at a time, using DHCP reservations for the satellites and a fixed IP for the "main AP". The whole system takes several (5 or more) minutes to adapt to each and any config changes you make. A full system reboot can take over 10 min... So be patient!
However now that is is all running it seems to be stable for the past couple of weeks.
One observation -I wish the wireless backhaul radios would shut off when they detect a wired backhaul. Running a wifi / spectrum analyzer you can see hidden the 2.4 & 5G backhaul radios blasting unused. I have no idea if this creates unnecessary "noise" and interference.
I now have great (fast) coverage into each corner of my house. The system as a whole does NOT seem to manage the band steering and roaming as well as I would like, but it is a decent compromise.
ekhalil
Jan 24, 2019Master
The wireless backhaul hidden networks will not shut off when using wired backhaul. I guess they are meant to be standby to take over in case anything happens in the wired cable. You can manually shut them off using telnet commands if you wish.
