SetMeUP
Jan 23, 2019Aspirant
Possible set up RBK23 with Ethernet backhaul
Hello Everyone,
So I'm looking to buy this Package from Amazon. The RBK23.
https://www.amazon.com/NETGEAR-Orbi-Ultra-Performance-Whole-System/dp/B07CQDHPFT/ref=sr_1_1?ie=UTF8&qid=1548227...
ekhalil
Jan 24, 2019Master
brettich wrote:
One observation -I wish the wireless backhaul radios would shut off when they detect a wired backhaul. Running a wifi / spectrum analyzer you can see hidden the 2.4 & 5G backhaul radios blasting unused. I have no idea if this creates unnecessary "noise" and interference.
The wireless backhaul hidden networks will not shut off when using wired backhaul. I guess they are meant to be standby to take over in case anything happens in the wired cable. You can manually shut them off using telnet commands if you wish.
brettich
Jan 24, 2019Guide
Thanks I will try that today.
