SetMeUP
Jan 22, 2019Aspirant
Possible set up RBK23 with Ethernet backhaul
Hello Everyone,
So I'm looking to buy this Package from Amazon. The RBK23.
https://www.amazon.com/NETGEAR-Orbi-Ultra-Performance-Whole-System/dp/B07CQDHPFT/ref=sr_1_1?ie=UTF8&qid=1548227...
SetMeUP
Jan 23, 2019Aspirant
Thanks for the advice. I'm not super tech savvy but I have enough persistence to eventually get my equipment working. But still if I can run an extra wire over figuring out how to update the firmware, I guess the easier option here would be to just go with recommended set up of having my modem connected directly to my Orbi router and then my satellite that's farthest from the router to connect to the Orbi router with an Ethernet.
THANK YOU VERY MUCH FOR YOUR ADVICE!
brettich
Jan 24, 2019Guide
One more comment - Make sure to set everything up as you want - where you want it - using the normal default wireless backhaul settings first. Test everything and make sure the system is running stable with the latest firmware for a while.
Create two DHCP reservations for the Satellites
Then one at a time switch the satelittes over to wired. -This seems to work better for most.
You should see the sattelites switch from Wirelss to "Wired" under the attached devices page of the main AP.
My 2c
