kuno2501
Jan 05, 2022Guide
Possible solution for Orbi dropping connection (when connected to satellite)
I’ve had Orbi (RBR50 with a couple of Satellites (RBS50)) for a few years and been very happy with it, until I started experiencing intermittent connection issues since upgrading the firmware to the ...
kuno2501
May 10, 2022Guide
Hello FURRYe38,
The Router Firmware Version V2.7.3.22
And the satellite and the modem are at least 30 feet apart.
There are only a few neighbors and I have tried different channels, and I have also tried factory reset...
The problem is simple: the connection between the satellite and the router is just not reliable...
May 10, 2022Guru - Experienced User
You might try loading new FW. RBS first then RBR lastly with a wired PC and web browser then factory reset and setup from scratch.
I would bring the RBS near the RBR while you update everything and factory reset and setup from scratch.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Traffic Meter.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
kuno2501 wrote:
Hello FURRYe38,
