a235301a's avatar
a235301a
Follower
Jan 27, 2019
Possible to use an RBS20 with an RBK50
As the title states, is it possible to use an RBS20 with an RBK50 router?  Or do I need to use an RBS50?
  • ekhalil's avatar
    Jan 27, 2019
    Yes, it's possible to use RBS20 with an RBR50 router.
    The backhaul thoughput will then be decided by the max backhaul throughput of the RBS20 which is 867 Mbps.
    On the other hand, an RBS50 has 1.7 Gbps backhaul.
    Good luck :)
