zollen
Oct 02, 2021Aspirant
Possilbity getting hacked with a short admin password?
I have been using my ORBI (RBR50) for sometime, My admin password is relatively short knowing that Anywhere Access is disabled. Do I have still to have to worry about getting hacked remotely? How do ...
- Oct 02, 2021
(almost) Yes. Any of the web "open ports" web sites will identify ports that are forwarded to internal hosts as long as the internal hosts have the port ready to accept connections.
For example, suppose I forward port 80 (http) to 192.168.1.22. If there is a computer at 192.168.1.22 with port 80 ready to accept connections, then those web sites will say, "Port 80 is open". If there is no computer at 192.168.1.22, or whatever is there will not accept connections on port 80, then those web sites will say it is not open.
Hope that makes sense.
zollen
Thanks for the quick reply. Would any online PC security test able to identfy any open ports on my router?
For example
https://www.grc.com/x/ne.dll?bh0bkyd2
CrimpOn
Oct 02, 2021Guru - Experienced User
