briansh
Mar 30, 2020Tutor
Post Firmware Update Signal Strength Levels
I did a firmware update yesterday. Before the update, signal strength to my guest network, that my son was using to play games was strong. post network, signal strength to the guest network seems to...
briansh
Mar 30, 2020Tutor
Just for background, the Router and Satellite 1 were added at the same time. Satellite 2 was added later. Both Satellites seem to be connected to the router as the lights in the Orbi app are green from Satellite 2 -> Satellite 1 -> Router -> Internet.
tomschmidt
Mar 30, 2020Virtuoso
What versions of firmware are now on the router and satellites? V2.5.1.8 is the current latest for RBR50 and RBS50.
- brianshMar 30, 2020Tutor
Looks to be all the same version...
Router firmware version: 2.5.1.8
Satellite (1) firmware version: 2.5.1.8
Satellite (2) firmware version: 2.5.1.8
- Retired_MemberMar 30, 2020
Why did you upgrade?.
- brianshApr 01, 2020Tutor
Thats a good question! Nothing was wrong, however the update was available so I decicded to take it. I can't roll back right?
Thanks VAJim
Retired_Member wrote:Why did you upgrade?.
