briansh
Mar 30, 2020Tutor
Post Firmware Update Signal Strength Levels
I did a firmware update yesterday. Before the update, signal strength to my guest network, that my son was using to play games was strong. post network, signal strength to the guest network seems to...
Mar 30, 2020Guru - Experienced User
briansh wrote:I did a firmware update yesterday. Before the update, signal strength to my guest network, that my son was using to play games was strong. post network, signal strength to the guest network seems to be very weak - < 1Mbps. Also, my network map/diagram before the update was a triangle with the router at the top and the 2 satellites at the base. Post update, the map is a straight line to the internet - no triangle. Also when I look at devices connected to the satellite via the Orbi app, it appears like everything is connected to the Router - which would certainly explain the signal strength. We did a reset of the router, do I need to reboot and bring on the satellites down during the reboot? The timing may also have been off doing a reset.
Any assistance appreciated.
briansh
Mar 30, 2020Tutor
Size of home is about 2500sqft. The Router is downstairs and the 2 satellites are upstairs. When I installed the satellite 1, it connected after I adjusted the location, and satellite 2, which I installed a few years later, connected as well. Both are more than 30 ft though.
Happy to enable what you mentioned, where would I enable - via the app , or on the Netgear site via the router login?
- FURRYe38Mar 30, 2020Guru - Experienced User
RBRs web page using a web browser on a PC or laptop.
- brianshMar 30, 2020Tutor
There looks to be some difference in the results the app shows and the website - will use the website as the most accurate source.
briansh wrote:Size of home is about 2500sqft. The Router is downstairs and the 2 satellites are upstairs. When I installed the satellite 1, it connected after I adjusted the location, and satellite 2, which I installed a few years later, connected as well. Both are more than 30 ft though.
Ya seem that users are seeing odd issues with the Orbi app.
