briansh
Mar 30, 2020Tutor
Post Firmware Update Signal Strength Levels
I did a firmware update yesterday. Before the update, signal strength to my guest network, that my son was using to play games was strong. post network, signal strength to the guest network seems to...
briansh
Mar 30, 2020Tutor
Size of home is about 2500sqft. The Router is downstairs and the 2 satellites are upstairs. When I installed the satellite 1, it connected after I adjusted the location, and satellite 2, which I installed a few years later, connected as well. Both are more than 30 ft though.
Happy to enable what you mentioned, where would I enable - via the app , or on the Netgear site via the router login?
Mar 30, 2020Guru - Experienced User
RBRs web page using a web browser on a PC or laptop.
