briansh
Mar 30, 2020Tutor
Post Firmware Update Signal Strength Levels
I did a firmware update yesterday. Before the update, signal strength to my guest network, that my son was using to play games was strong. post network, signal strength to the guest network seems to...
briansh
Apr 01, 2020Tutor
Is there anyway that I can find out what previous version i was running, or would you strart from the last version (newest)
briansh wrote:
Retired_Member wrote:
briansh wrote:Is there anything else that I can do?
Troubleshooting:
1) reset router & satellites
2) reset modem
3) rebooted router
a) reset satellites
4) Went through New Setup via the app in case that would fix anything I had set/done incorrectly.
try and download the previous version you were running
Ooh, ok. thanks @Retired_Member.
or the first version (oldest)
briansh
Apr 01, 2020Tutor
ignore the last response - sorry.
Should have read, is there anyway to find out the last ver I was running? If not, would you start with the oldest firmware, or the newest (1 vesion back)?
Thanks
