justthinking
Apr 11, 2020Follower
potential buyer of RBK50 for 3 floor home with router in basement
Looking at RBK50 for basement plus 2-story home. New ATT fiber router in basement. 2500 sq ft per floor. Looking at Eero, Google, and Orbi. like the 3-band idea, but worried about signal strength t...
Apr 12, 2020Guru - Experienced User
House size Find Your Orbi System:
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Systems
justthinking wrote:Looking at RBK50 for basement plus 2-story home. New ATT fiber router in basement. 2500 sq ft per floor. Looking at Eero, Google, and Orbi. like the 3-band idea, but worried about signal strength through floors to the main base, as opposed to eero and google units that all talk to each other. (old guy with a dusty engineering degree, but no modern computer/wireless technology stripes, so somewhat clueless on the acronyms and numbers).
1) with base unit in basement, should I put satellite on first floor? will it cover 2nd floor well?
2) why doesn't RBK50 show up as a model. what is the RBK53?
3) I have one TV we use is a dumb analog Sony with no HDMI. If I plug a new Mi Box into an HDMI to three-wire RCA jack converter, will it connect properly with Orbi and then how do I control what it does?
thanks in advance.
