wmcneil
Jun 04, 2020Tutor
Potential Orbi Buyers be aware: NO whitelist capability for port forwarding
I have a Obri RBR50 and two RBS50 satellites, running the newest (v2.5.1.16) firmware. I have a need to open ports for various reasons. To my disappointment, I realized today that my orbi router has...
CrimpOn
Jun 04, 2020Guru - Experienced User
Your observation is correct that Orbi does not provide a method to limit connections when forwarding ports. That appears to be left to the device that will be accepting the connections. As far as I am aware, none of Netgear's residential routers have such a feature. What I do to strictly limit access is set up OpenVPN so that only devices with the correct OpenVPN credentials can access my local LAN.
It would be really useful to know which residential routers feature whitelists on port forwarding. (I keep a lists of "things to research" for when it comes time to replace my Orbi system and this would be something to keep track of.)
- wmcneilJun 07, 2020Tutor
VPN is a good solution unless the remote machine is already running another VPN (work machine for example) and that already existing VPN does not allow split traffic.
Doing a quick survey, there are a good number of routers that allow you specify a single IP address to qualify port forwarding, but not so many that allow multiple IPs (whitelist).
CrimpOn wrote:Your observation is correct that Orbi does not provide a method to limit connections when forwarding ports. That appears to be left to the device that will be accepting the connections. As far as I am aware, none of Netgear's residential routers have such a feature. What I do to strictly limit access is set up OpenVPN so that only devices with the correct OpenVPN credentials can access my local LAN.
