cattrieu
May 28, 2017Tutor
Power adapter
Since I cannot find any information of the ouput voltage of the adapter, so does the power adapter shipped with Netgear Orbi support 220v/50Hz power network (non US standard)?
peteytesting
May 28, 2017Hero
its 100 to 240v so can be used with a converter if needed but be aware the fcc wifi rules for the staes may not be correct for your region
- cattrieuMay 28, 2017Tutor
But how about the Hz? 50Hz?
- peteytestingMay 28, 2017Hero
secondary o/p is d/c so freq doesnt really matter
It does matter since I bought an electronic device from overseas and the voltage input was 60Hz so there were some problems when I was using that device.
