cattrieu
May 28, 2017Tutor
Power adapter
Since I cannot find any information of the ouput voltage of the adapter, so does the power adapter shipped with Netgear Orbi support 220v/50Hz power network (non US standard)?
timch
May 29, 2017Luminary
Petey, I guess you mean voltage and current......... Perhaps you should be reading up..... ;)
- peteytestingMay 29, 2017Hero
timch wrote:
Petey, I guess you mean voltage and current......... Perhaps you should be reading up..... ;)um amperage = current
voltage is irrelevent as all new power supplies are 110-240v these days
wattage is a calculation of voltage and amps
so i stand by what i said
- ImNoOneJun 08, 2017Guide
Frequency DOES matter when it comes to ANY "transformered" devices. Overheating and/or burnout can occur if 60 Hz rated devices are used on 50 Hz current, as there is not enough iron in the induction cores, and the devices overheat. With "switching" power supplies, there is less of an issue. The power supplies SHOULD have a voltage/current/frequency input rating printed thereon.
- cattrieuJun 08, 2017Tutor
Finally, someone understands what Frequency means
