AeroHead33
Nov 30, 2022Follower
Power Fails & ORBI
Not at all happy with the amount of work to regain internet after a power fail/bump. ORBI is very unfriendly, the router has no indications, and yet the satellites at least go purple/red’ish. I usual...
michaelkenward
Dec 01, 2022Guru - Experienced User
After a power cut, you need to check that the whole network starts in the right order.
Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
It may help to reboot the whole network in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
