CIChien
Mar 09, 2017Aspirant
Power LED of Orbi Satellite is blinking green
Dear friends, I got an issue: The Power LED of My Orbi Satellite is blinking green. What does this mean? In this situation I have also noticed that, the WiFi signal is weak. (I suppose ...
- Mar 11, 2017
The cause had been found.
I plugged the adapter into an old power line.
The voltage was unstable. That's why it was blinking green.Changing to an other power line solved the issue.
Thanks.
CIChien
I am sure that, it is blinking in green.
So, I cannot figure out what happens.
(I read the document and cannot find "Blinking green" in the chart.)
That is the reason, why I posted this message to ask, who may know about this.
The firmware version is 1.5.0.12.
>> (I suppose that, the signal from the Satellite is unstable or even stopped.)
Mikey94025
Mar 10, 2017Hero
I suggest you contact Netgear support. There is a link for that next to Pulsing Red for the power LEDs in the chart: http://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean?cid=wmt_netgear_organic
- CIChienMar 10, 2017Aspirant
Thank you for your suggestion.
I will contact the support.
- CIChienMar 11, 2017Aspirant
Thanks.
